Thread: Cruise Control
Old 06-10-2010, 06:13 PM   #3
batmmannn
batmmannn's Avatar
Default Cruise COntrol
I was doing some reading and I read that it could be the switch on the clutch or brake that disengages the CC. Also I read that if you drive while resting your foot on the clutch that could keep it deactivated as well. Read that switching rear tires could confuse it. Seems like a lot of ifs there.
I will try it again. Others say it just starts working again or is intermittent. My cables seem OK, will check the fuse today and try it again. Seems like JB weld might be good to reattach that boot. Thanks
UPDATE
Well go figure! I just took it to the local General Store and it works! I made sure I kept my foot off the the clutch and got it above 25mph, tried it and it worked perfectly. I have no idea for sure why! I guess this thing just is coming back to life, I have some creeking in my front end I am looking to see if this has grease certs to lubricate the front end. Thanks for your help.
