Old 06-10-2010, 04:44 AM   #1
Semper_Fi
Semper_Fi's Avatar
Semper_Fi is on a distinguished road
Originally Posted by fullthrottlesrqsupra View Post
the supra is way too heavy for a rotary they make loads of power but no torque and you need torque to get 3400lbs going the great thing about rotary engines is that they rev out to 12-13k or higher very easily and make power straight through the rpm range but at like 1000hp theyll make about 400ftlbs or less
Ive built a couple rx7 in my day... And by all means... your comment.
But... one mans word of mouth wont speak... so ill show u different with the internet... wikipedia
The 13B-DEI was turbocharged in 1986. It features the newer four-injector fuel injection of the 6PI engine, but lacks that engine's eponymous variable intake system. In '86-'88 engines the twin-scroll turbocharger is fed using a two-stage mechanically actuated valve, however on '89-'91 engines a better turbo design was used with a divided manifold powering the twin-scroll configuration. For engines manufactured between '86-'88 output is rated at 185 hp (138 kW) at 6500 rpm and 248 N·m (183 ft·lbf) at 3500 rpm.
1989 supra turbo-
uh-60 blackhawk... My life
Semper_Fi is offline   Reply With Quote
