Old 06-10-2010, 04:35 AM   #1
batmmannn
batmmannn's Avatar
Default No Power
Check your 7.5amp fuse for the domelight/hazard behind the kick panel on the drivers side first off. Once you get power there likely you will still have trouble with the dome light.I posted what I did to fix mine so run a search on dome light and you will find my post.
http://www.toyota-supra.info/forums/...ome-light.html
