06-05-2010, 08:24 PM
#2
AEM EMS
Originally Posted by joshtexican
Ok so when torqueing the head. Do I need to have the "TIMING BELT CASE" on the block already, before installing head? As shown below...
If it’s off already put it back on before fitting the head, but its advisable to fit No2 timing belt cover after you’ve bolted the head down, the reason being " if you skim the head, the head will sit lower down and the bottom part of No 2 timing belt cover could foul the top of the ally timing belt case (as shown in your parts image)" If that makes sense. Never been an issue with me, but I suppose if you removed a large amount from the head and used a standard gasket the bottom part of No 2 timing case cover could need trimming down.
