Thread: 2 crank seals?
Old 05-25-2010, 05:12 AM   #5
batmmannn
batmmannn's Avatar
Default 2 seals!
Hey that drawing looks like it slightly smaller and thick. I bet that is it. I should use it then. Thanks Jim! Scott
ooops just ran the part number came back as Crankshaft front oil seal 90080-31022. Strange it's a crank seal but does not fit nor go on my car that I can see. maybe it crosses over to the oil pump seal. I will have to check with the dealer. My oil pump seal appears to be fine though.
Updated!
OK Mystery solved. The extra seal in the Felpro pack is the oil pump seal. Not gonna replace it cause it is not leaking. Not Broke? Leave it alone! The guys at the Toyota dealership sold me an oil pump seal knowing I needed a crank seal go figure! Evidently the oil pump seal on our cars also fit other cars as the crank seal.....
