Thread: Opinions??
Old 05-25-2010, 03:41 AM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
Originally Posted by 87mk111 View Post
From waht i remember, the XTD cluthc is a scam. It's just a stock one that is painted. heres the link for the article on supramania: http://www.supramania.com/forums/sho...td+clutch+scam
hope that helps.
im running an xtd stage 2 in my car its pretty good definately not stock has a carbon kevlar disc nice engagement
its rated for 380 but from past expierence itll hold about 300 just knock like 80-90 off your rating and your good no slip and my old clutch was slipping it was an oem exedy
edit i read that post my clutch is noticably not stock it was a different shape even then stock had few but wider fingers and they were obviously heat treated also my pedal is a bit stiffer and my clutch was not stamped aisin like they were saying though my clutch was for a ge not a gte so it is quite a bit different its a push type not a pull type
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
