Thread: okay so..
Old 05-22-2010, 01:55 PM   #7
turbonicsperformance
turbonicsperformance is on a distinguished road
yes but if the noise hasnt been going on very long it will be fine and yes you could do this just like i said before make sure you torque the rods with a good torque wrench and make sure to lube the rod bolts and bearings when installing if you plan on doing the main bearings they are difficult in car but they are honestly more than likely perfectly fine main bearings rarely fail
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
