Old 05-21-2010, 11:20 PM   #1
batmmannn
batmmannn's Avatar
Default Wtf?
That makes no sense at all, changing plugs could not do this unless you made some errors in reassembling the Y assembly which has cause a fuel problem. Did you use new gaskets on your Plenum when you put it all back together? Did you mess with the throttle sensor or just leave it attached? Did you replace the plug wires one at a time so you made sure you have them on the distributer in the right places? Could they be out of order on the distributer cap? Maybe someone else could chime in
