Thread: Starting Issues
Old 05-20-2010, 05:24 AM   #1
SuperSpartan
SuperSpartan's Avatar
SuperSpartan is on a distinguished road
Originally Posted by fullthrottlesrqsupra View Post
not much but its not a good idea to change pulleys either way and imho underdrive crank pulleys are horrid ive seen them do way more damage then they do good the principles behind it is just retarded you dont add power and take away cooling efficiency also the crank pulley would work opposite of the way your wanting it will slow everything down not speed it up honestly like i said before its probably your fusible link it can look perfectly fine and be bad check your voltage at both sides of this
could i get a wee bit more details on where and how to properly check my fusible link?
1990 Toyota Supra Turbo!!
www.cardomain.com/ride/3067504
SuperSpartan is offline   Reply With Quote
