Old 05-17-2010, 10:15 PM   #10
batmmannn
batmmannn's Avatar
Default Still no start
Hello every one. I swapped out the fuel pump relay with my other car, I did the jump to test the fuel pump propped open the vane turned on the key went back to the gas cap and listened. I can hear the fuel pump running. There is a slight buzz but barely audible.
Took the wire off the jumper, took off the prop to the vane tried to start the car and it fired for about 2 seconds then died again. When I jumped it I could not hear any return flow but after cranking it for about 20 seconds I could smell fuel but still not starting.
Could it be flooded now? The T assembly that runs across the rear of the valve covers is not on tight the rubber hosing is cracking and needs to be replaced.. would that stop it from starting?
I really am getting nowhere here with this, I am thinking fuel filter now, I have swapped the starter relay, the main, the fuel pump is making sound, I have fire to the plugs and after sitting for some time it sometimes tries to fire.
Any Ideas? Thanks for your input. Scott
Update: I just went out and took off the cold start line. I jumped the box and it started sending fuel, took the jumper off and turned the key and it was pushing fuel so I am at a loss here. I suppose compression test is the next test? I am definately getting fuel Could it be flooded now after doing the jumper test?
I am so puzzled. Compression test will tell me something I guess. Just doesn't make sense that it would die so suddenly does it if it is a head gasket or bad compression doesn't that happen over time slowly? I thought you had to be blowing tons of steam or smoke before a car would eventually stop running from compression. Help?
Any ideas suggestions?
Thanks
