Old 05-15-2010, 05:02 AM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
its not just valve tap or lifters and your timing won't cause a noise just a rough idle or sluggish condition it really sounds like you broke a valve spring but only one since it is a very slow tick sound were you revving it when this noise first developed and does it become less apparent or more when you rev? also i dont think your ignition timing would cause this without ALOT of other signals (hard slow start, overheating, cracking pistons, and alot faster noise) but imho it is a broken valve spring you should pull the valve covers and check them its not that hard of a job just remove intake where it splits and take off the valve covers the wires can stay in and everything
basic rule is a noise at half engine speed is valve noise or cam noise
full engine speed is ignition sound "arcing" or rod/main detonation etc.
turbonicsperformance is offline   Reply With Quote
