Old 05-15-2010, 03:34 AM   #1
supraflymkiii
supraflymkiii's Avatar
supraflymkiii is on a distinguished road
to see the timing marks on the cam gears you take the panel off of the front of the engine that says 7m-ge. I actually just recently put a new engine in my jeep and it has coil on plug and its a little tricky to get on. So i put it on and thought it was on all 6 plugs so i started it up and it was idling shitty and had a miss and was making a loud arcing sound so i looked a little closer and realized the boot wasn't on the sixth sparkplug stuck it on and it ran perfect. As for seeing it in the dark I don't know if you would see it or not its worth a try.
supraflymkiii is offline   Reply With Quote
