Old 05-12-2010, 12:24 PM   #3
professorbob
professorbob is on a distinguished road
Default Fan and Radiator Removal
Is there anything I need to note before I start the radiator and shroud removal.
Also, Should I try and drop the whole exhaust system from the header back to the rear muffler or should I separate it at the catalytic converter.
I suspect that it is better to remove the nuts at the differential and take down the pilot bearing to remove the drive shaft as one unit. Right?
professorbob is offline   Reply With Quote
