Bad Form in my Forum.
Look,
I apologize for any incorrect "Forum" etiquette that may have caused any problems with my post. It seemed pretty lonely, so maybe I was just re-hashing things too much. Either way you guys helped and I appreciate it.
The car's biggest issue was the injectors being clogged due to sitting for over a year. (I may have failed to mention that). I read somewhere to run the injector additive, I used Lucas, and after 2 or 3 tanks the car runs much better. It stills runs a little rich below 3K and will not accept full throttle consistently, but it's getting better the more I drive.
If my check engine light is not flashing anymore and the EFI has been cleared, does that mean that I have no error codes? The light works fine, just wasn't sure what came first the flash or the jumper?
Thanks- I love this car.
