Old 09-04-2005, 12:56 AM   #1
azzurro
azzurro is on a distinguished road
Default Thanks for the ideas!
I may need to make a new turbo manifold so i can get more room. Looks like there isnt even enough room on the supra to even have 2 separate 2" pipes ;-X.. who knows. Yes, positioning the turbos higher in the engine will give me room. Ill have to research it...
The car dynoed at 144rwkw but that reading was with 4 boost leaks - 1 on my HKS BoV (that i fixed by dissconecting a connectyor pipe in the BOV)... 2 on my new FMIC piping (wasnt a bad job for a first time FMIC done all on my own) and 1 on the inlet. Boost was at 12psi.
Now i fixed all that the mill runs 15psi no dramas, doesnt hit fuel cut and is very drivable for an easy ride, and feels A LOT quiker and smoother.
Mods are all bolt on.
1989 MKIII Supra GT Ltd with 1-G GTE TT
Stock ECU
Stock Internals
Stock reconditioned Turbos (jeez that took me for eva to get em out)
HKS BOV
HKS Raid Pod
HKS Cat bak, larger 3" front pipe
Manual Controller set @ 15psi
New Custom bigger FMIC with Cermaic Polished pipes with minimal welds or joins (im a welder)
Custom made stiffer springs 40mm lowered - coilovers coming
19" gold Zanetti wheels.
Momo wheel
Guagues
Stock Burgandy Velour Trim with Stock white paint - Spoiler removal on its way.
J-Spec 2din CD (with FM modulator for Aus FM)
JVC speakers
To come : Haltach ECU, removed AFM, Dump pipes and a tune.
Ill let you know if i end up making custom dumps i can do it but i want to take the easy way out and buy them... lol we will see....
Cheers ;-)
azzurro is offline   Reply With Quote
