Old 05-09-2010, 11:39 PM   #1
907mge
907mge's Avatar
Those "gaskets" are called strut mounts and I don't know why you call the struts JDM. I'm sure the USA model uses the same suspension as a Jdm one. Be careful when messing with struts since the springs can be under tension. And no it is not that easy to do struts on the mk3 with the double wishbone suspension. It took me about a day and a half but i also did the sway bars. Good Luck.
