Old 05-09-2010, 04:24 PM   #1
nfa_automotive
nfa_automotive's Avatar
nfa_automotive is on a distinguished road
Originally Posted by PNK SLP00 View Post
well the oil pressure gauge is not working so i really dont know. you think if the headgasket is bad the head might have warped also and thats why its ticking? ive never taken part a 7mgte or any motor other then a civic. so it will be a learn as i go kinda thing. ill def be pulling the rods out and checking the crank/sleeves and the pistons and see what happens... if i post pics of it all apart would that be help ??
No the head gasket is just something that happens on a 7M.
And it might not be the oil pressure gauge. Sounds more and more like a spun bearing. Oil pump might be dead.
Do some more recon and let us know. Easiest way to check for a oiling problem, pull one of the cam caps off, if they look scared, if they are your going to have to pull the motor apart and see what failed.
1987 Supra Turbo Targa Blue 5spd 175K, 3" Exhaust from Turbo back, Lowered 1.5", 89 Steering Wheel and Climate Control, JDM Power Folding Mirrors, HKS Fan Controller, Greddy Turbo Timer, HKS EVCIII Boost Controller, Boost Gauge, Deleted Boost Gauge in Cluster for Volt, MKIV Non-Turbo wheels
1987 Supra N/A Coupe Blue Auto - Parts Car
1987 Supra Turbo Coupe Black 5spd - Bought with a spun bearing - RIP
1987 VW Jetta GTI Auto 89k
nfa_automotive is offline   Reply With Quote
