Old 05-06-2010, 04:02 AM   #1
supraflymkiii
supraflymkiii's Avatar
supraflymkiii is on a distinguished road
The 7ms stock throttle body flows enough air the way it is I don't understand why you want to put a q45 t.b. on. Do some research before you start asking questions like this. If you would've researched you would have realized you can't just do the LEX AFM without installing larger injectors as well. I wouldn't be surprised if you're running lean right now because you're gettin more air than normal and not getting the extra fuel to compensate for it. Run like that to long you'll screw up your engine.
supraflymkiii is offline   Reply With Quote
