Old 05-03-2010, 07:19 PM   #13
TripleC
TripleC's Avatar
I welded it back together. I Took out the diff and swapped it for a welded this weekend and finished the welding on the botom side of the subframe Rail.
I started by welding the actuall frame back together then created some 3/4 inch flat pieces of steel and welded them on to the outside of the frame for more support. I also Drilled holes in the Metal piece so i could fill in a rosette weld and make it stronger. Not just an edge or rosette weld I put on some extra leyers on for mental security.
The frame is holding great and trust me i have been beating it to death. In fact it currently isnt running but thats not because of the subframe. i have ignition or Mainly fuel delivery problems
1JZGTE ,R154, Hallman Boost Controller, HKS bov, HKS Mushroom top Air Filter, HKS Front Mount Intercooler, Greedy Turbo Timer, PLX300 AFC, Custom Divorced Y-pipe, Custom Intercooler Pipeing, RS-R Concept Exhaust, Optima Red Top Battery, Strut bar Brembo Rotors, A1 Traction arms, Megan Coilovers, Stern ST 2 wheels rear 265x30 r19 - front 245x35 r19, New Front Lip, 18 x 8 and 18 x 9 MRR HR2 with whatever for Drift treads
2 additional C12A turbo's(Extra)
