Old 04-30-2010, 11:11 PM   #1
Cameroonski
Cameroonski is on a distinguished road
Here's the update...
The Check Engine light was not coming on with the ignition on. It DOES come on when terminal W is connected to E1 (computer ground) as well as a body ground. The computer ground into the engine block is good.
I'm also getting these voltages...
BATT has 12v
M-REL still has about .08v
IG S/W had about 1.23v
+B is not getting anything
Also, on the Diagnostic Box...
From +B and the battery i have 12v, and from Fp and the batter i have 12v, but both to the same side of the battery and when i test it in between them it is 0v. Im not sure if this means anything...
All of this seems like the ECU is funky, but i have tried two different ECUs, and i find it highly unlikely that the same odd problem would lie in both. So short circuit somewhere maybe?
Please i need some help..
Cameroonski is offline   Reply With Quote
