Old 04-28-2010, 01:52 PM   #11
TripleC
TripleC's Avatar
Check the top of the Subframe cage that goes over the Rear end for cracks. It should not be missaligned and i have never herd about any differential swaps causeing the issue of not ligning up.
To fix your Problem you can take a hole saw and drill into the subframe where the bolt and cage are located.(this is what i did on both sides).
It wont take you too long to do but you will need to weld the hole you cut out back in (I used a washer i bought at ace hardware) after you put in your new nut . I removed the cage inside and made my own design.
basically a piece of flat 1 inch steel with a Bolt welded on to one end so it had a lever or pivit point to press agains if i tightened or loosened them.
it sounds like something else is wrong. Check the Subframe next to the tank there are 4 mounting bolts you could have broken one of them and it twisted the Subframe.
1JZGTE ,R154, Hallman Boost Controller, HKS bov, HKS Mushroom top Air Filter, HKS Front Mount Intercooler, Greedy Turbo Timer, PLX300 AFC, Custom Divorced Y-pipe, Custom Intercooler Pipeing, RS-R Concept Exhaust, Optima Red Top Battery, Strut bar Brembo Rotors, A1 Traction arms, Megan Coilovers, Stern ST 2 wheels rear 265x30 r19 - front 245x35 r19, New Front Lip, 18 x 8 and 18 x 9 MRR HR2 with whatever for Drift treads
2 additional C12A turbo's(Extra)
