Old 04-28-2010, 11:38 AM   #10
StonecoreTx
StonecoreTx is on a distinguished road
Angry
Well a freind of mine had the bolt I needed from his Cressida build, which is the good news ( I belive it's a m14 x 35mm @ 1.25tp)
we both jacked up my car to put the bolt in yesterday and ran into quite a problem. the bolt holes where the diff mounts to the suframe are not aligned. spent an hour trying to get some play to somehow get it in but there was no luck. i'm guessing the subframe is tweaked seince there was only one mounting bolt..? =( the bolt goes in about halfway then taps the subframe, if you put your finger in the hole it feels like the hole is shifted like 1/4 inch to the side, if i use my pinky i can almost feel the cage nut inside the xmember but theres no way to get the holes to line up for the bolt to go in.
does this mean I've gotta get another subframe?!?! any ideas/options?
86.5 mk3 supra 7mgte r154
StonecoreTx is offline   Reply With Quote
