Old 04-26-2010, 04:15 PM   #1
MA70-3.0GT
MA70-3.0GT's Avatar
have you tried the fp & b+ jumper trick in the diag. box yet? (check tsrm to make sure my memory's not lying on those terminals to jumper before you connect anything 'cause I ain't exactly on form today!!!).
This should result in the fuel pump running permanently with the ign. on & IIRC bypasses the relays & fuses. If the car's then running but rough & with seemingly random codes as you described then it could possibly be the ECU or it's connections/earthing, I'd check/double check/replace the cheap stuff first though as you've started doing, maybe even swap the fuse again in case it looks fine but is duff, I've had 'em like that before. (if it is gone again maybe check how much current the pump is drawing too?) and only spend on an ECU after you've exhausted every other route.
