Old 04-25-2010, 08:56 PM   #1
StonecoreTx
StonecoreTx is on a distinguished road
Originally Posted by TripleC View Post
Last night i got under the car and realized that one of the main bolts to the Differential was missing. So i figured what the hell i might as well pull out the other one take it to a parts store and find something similar Right!!! Wrong half way through backing the bolt out it broke the nut end off from inside the Subframe. Now i have to cut it off with a sawsall and begin surgery
OOOOHHHH SS######T
Attachment 2790
What now any Suggestions?
I thought about cutting an access hole in the subframe with a grinder or torch then weld in a new one but it is kind of an uneven surface and it would be hard to get a welder to fit under the car and in a blind hole to weld a bolt perfectly in place, unless i dropped the hole subframe? SOuds like alot of work
Take Diff out Drill out old hole with larger hole saw - weld bolt to piece of subframe then weld back in the piece i cut out ? I thought this would be the easyest
any other ideas, I didnt see any access holes on the frame so it looks like i am going to have to make my own.
Please help
I think I'm having the same problem...eccept I'm just missing one of the two diff mounting bolts near the drive shaft. I hope mine doesnt break during replacing it, after reading this i'm goanna get me some bolt breaker.
what size bolts/washers are these?
86.5 mk3 supra 7mgte r154
StonecoreTx is offline   Reply With Quote
