Old 04-23-2010, 05:02 PM   #1
midwestmk2
midwestmk2's Avatar
As far as headgaskets i would go with the HKS 1.2m. You will also need to have the head milled to garantee that it is square and will seal properly..By doing so you will also raise compression slightly and in turn a few extra HP.. I would also torque the head bolts down about 20ftlbs more than the tsrm recomends if you go studs then go up to 40ftlbs more.. Now the cams i have heard good things about the GUDE cams although HKS "did"
make cams for the 5mge but you will have to find a set of used ones or have some custom ground to there spec which you would need them for someone to copy anyway.. Good luck on the build i gave up on my 5mge days.. Ive been through 5 of them in 4 years.. Im going to do a SBC swap now..
