Thread: problems
Old 04-20-2010, 01:53 PM   #1
crzy-mk3
crzy-mk3 is on a distinguished road
Originally Posted by Krem View Post
are you getting spark at all? if so, try adjust your timing... if not... at least you know which end of the elec system you need to focus attention on. Also, did you get a new ECU with the turbo? 7mge != 7mgte on several different levels... including compression ratio..
i have power to the coil and distributor but no spark. i changed ECU and harness but still no spark
crzy-mk3 is offline   Reply With Quote
