Thread: engine problems
Old 04-19-2010, 12:08 AM   #8
vbryanv
vbryanv is on a distinguished road
Originally Posted by Life is Supra View Post
I have a problem at cold start the rpms goes at 500 and than stals.When got to work temp.its fine and work ok at 800.Sometimes when I goes hard on the right foot,the car sut down when I let the aceleration pedal off?And I hear some knocking sound at head of the engine-can somebody tell me what to do I didnt check the codes...
let me know what you find wrong. i have the same issue as you. hard to start, starts and stall. bogs around 1500rpm and past 1500rpm no problem. no start after hot. replace throttle position sensor plugs and there are no vacuum leaks or coolant leaks. any suggestions
vbryanv is offline   Reply With Quote
