Old 04-08-2010, 03:22 PM   #2
907mge
907mge's Avatar
Yes, physically they will fit but if you read, it has the wrong bolt pattern so if you can’t put it on the hub it doesn’t do any good. Plus a bigger rim is not always better. If you have too much rotational mass it can slow you down as far as acceleration goes. Usually the way it works is the more you spend the lighter the wheels get.
