Old 03-28-2010, 01:12 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by supraireland View Post
Yes, perhaps there is a misunderstanding, I have a Na-t 2jz-ge not a gte and I want to fit the tt style aftermarket intake for the GE, With the 90 mm throttle body but the sensor? I dont know what to do with it? when disconnected car revs up and down uncontrollably.
Where did you get the 90mm throttle body? Neither the 2jz-gTe nor the 2jz-ge have a 90mm throttle body...
The erratic revving may be a problem with your IAC valve/motor or a vacuum leak...
Life begins at 30psi.
