Old 03-24-2010, 01:19 AM   #1
Without knowing where it's failing you're not going to get anything but guesses....
Proper ignition advance timing is 10 degrees BTDC. Did you set this with the diagnostic jumper in place?
Yes, a bad coolant sensor can cause issues.
Have you checked for error codes? (See the first sticky in the MKIII FAQ)
Any mods to the car?
Is the air filter clean?
