Old 03-22-2010, 02:41 AM   #10
Bolts = 75ft. lbs.
Studs = 90ft. lbs.
If you're reusing the stockers check thoroughly for bad threads, pitting, and measure to make sure they're still within spec.
NOTE!!!! Torque specs change depending on what you're lubricating the friction points with (Head, washers and threads of the bolt). Those I've listed are for use when using a GOOD moly based grease. Don't forget to chase the block's threads too!!!!
