Old 03-19-2010, 02:16 AM   #1
rohin02
rohin02's Avatar
rohin02 is on a distinguished road
Which engine? 1G-GTE, 1JZ-GTE or 2JZ-GTE? In all of these cases I believe the airflow is determined through the measuring of manifold pressure via a vacuum hose... in which case btwilson86 is dead right, a bad vacuum hose is a very likely culprit.
Okay thank you i will get my mechanic to check it out this is a 1jz GTE engine.
rohin02 is offline   Reply With Quote
