Thread: Leakdown test?
Old 08-30-2005, 01:49 AM   #1
daiagaru2
daiagaru2 is on a distinguished road
a leak down test consists of compresing the cylinder and listening to the exhaust and intake valves.if you can hear air comming out of either you have a failure.i would get a compresion tester,pull all plug wires remove one spark plug at a time install compression tester(screw in kind)and crank engine until preasure is at max then simply listen to the exhaust valves for air leaks,then listen to intake vaves for air leaks.
daiagaru2 is offline   Reply With Quote
