No the intakes will not interchange.. The 7m is a 24valve motor and the 5 and 6m both use the 12 valve hemi head design.. The dizzy is also on the passenger side of the 7m versus ours on the driverside..The 6m is nothing but a 5m with a 7m crank and a different cank timing gear to make up for the stroke diference.. The intakes on the 5 and 6m are round and the 7m has a oval intake to unshroud the intake valves.. The exhaust side though is identicle.. The header will just need to be ground off a bit on the front to clear the power steering pump.. The turbo manifold should be a direct bolt on though..How you are a Admin and not know these simple things is confusing though.. Its called research and not just the model you drive. Every Supra from 1979 to 1998 should be known.. Hell do you even know what a Toyota 2000GT is? Im betting not..
