Thread: T-61 Turbo
Old 03-05-2010, 06:22 AM   #4
How high you can push a T-61 is not the same as how high YOU can push a T-61.... How high YOU can go depends entirely on the supporting mods... with 550's you needn't worry about the efficiency limit of that turbo; you won't reach it, at least not safely AFAIK.
The preferred calculation for determining injector size or HP limit with our engines is: target RWHP = cc/min - 25%. So, 550-137.5=412.5... so let's say around 400 to 425RWHP is the *recommended* cap... this isn't a physical law, most injectors can flow more, but it is SAFE.
