Old 03-04-2010, 06:32 AM   #1
MarkLinRacing
MarkLinRacing's Avatar
MarkLinRacing is on a distinguished road
Check for play in any of the bushings, ball joints and the tie rods... wheel bearings are another possibility. That's where I would start anyway.
Does the car pull to one side or the other at all? Any heavy or uneven tire wear?
Wheel bearings are only a month old on both sides so I doubt it's that.
No play in front end. I haven't really checked rear end since the wheel bearing install but when I had the car up on hoist last week to tighten up e-brake, I didn't notice any play when I was turning the wheel.
Maybe slight uneven wear on tires, but nothing serious enough I'd even consider pointing my finger at. The tires are not cupping.
The car does not pull either.
MarkLinRacing is offline   Reply With Quote
