Old 02-25-2010, 02:28 AM   #2
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
Ugh, well, the jig is up. The rain let up today so I pulled off the lower portion of the oil pan and took a look around the lower block section of my 1j. The oil was clean, but i've learned not to trust it. I spun the #3 rod bearing, nice little shards are on the bottom of the pan. BUT, there doesn't seem to be any major damage. I'm still thinking of getting the 2j block from the yard out here, but it also seems I caught it soon enough that I can rebuild the 1j after flushing the oil system a few times.
What a drag.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
