Old 02-21-2010, 09:39 AM   #1
The linkage for the reset button is the most common point of breakage on the trip meter; Repair for this generally requires a donor unless you're good at welding plastics. Sometimes, the spindle which carries the number wheels will break loose preventing contact with the drive gear... this can usually be glued back in place.
Resurfacing the flywheel is essential.
