Old 02-19-2010, 02:06 PM   #1
TripleC
TripleC's Avatar
Last night i got under the car and realized that one of the main bolts to the Differential was missing. So i figured what the hell i might as well pull out the other one take it to a parts store and find something similar Right!!! Wrong half way through backing the bolt out it broke the nut end off from inside the Subframe. Now i have to cut it off with a sawsall and begin surgery
OOOOHHHH SS######T
Name:	Differential bolt 003.jpg
What now any Suggestions?
I thought about cutting an access hole in the subframe with a grinder or torch then weld in a new one but it is kind of an uneven surface and it would be hard to get a welder to fit under the car and in a blind hole to weld a bolt perfectly in place, unless i dropped the hole subframe? SOuds like alot of work
Take Diff out Drill out old hole with larger hole saw - weld bolt to piece of subframe then weld back in the piece i cut out ? I thought this would be the easyest
any other ideas, I didnt see any access holes on the frame so it looks like i am going to have to make my own.
Please help
1JZGTE ,R154, Hallman Boost Controller, HKS bov, HKS Mushroom top Air Filter, HKS Front Mount Intercooler, Greedy Turbo Timer, PLX300 AFC, Custom Divorced Y-pipe, Custom Intercooler Pipeing, RS-R Concept Exhaust, Optima Red Top Battery, Strut bar Brembo Rotors, A1 Traction arms, Megan Coilovers, Stern ST 2 wheels rear 265x30 r19 - front 245x35 r19, New Front Lip, 18 x 8 and 18 x 9 MRR HR2 with whatever for Drift treads
2 additional C12A turbo's(Extra)
