Personal opinion after hearing that noise, take out a 45mm pistol, walk up to the car slowly from behind as to not scare it. Then do a nice double tap on the engine its dead. You also have to realize that with that noise being as loud as it is may not be the top end. Metal transmits sounds so it could be anywhere. I think you have the right idea replacing it will be cheaper than rebuilding. With the prices you showed there are cheaper places to find engines I know a guy in Dallas that has a 7MGTE for like 400 bucks ECU and everything.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
