Old 02-04-2010, 03:49 AM   #1
Then to set the spark advance, warm the engine up to normal operating temperatures and follow the instructions below:
EDIT: for some reason that attachment didn't work so well.... here's a link to the TSRM page on it.
http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=20
You MUST insert a jumper across T(E)1 and E1 in the diagnostic box when setting/checking the timing. Additionally, NO CODES can be present, the throttle MUST be fully closed and the A/C MUST be off... and the engine needs to be at normal operating temp. The timing is supposed to be at 10 degrees BTDC, the ECU will advance it further based on sensor feed back, it's not an old Chevy, advancing it further yourself will actually do NOTHING.
