Thread: wiring harness
Old 02-03-2010, 03:00 AM   #3
supradaddy0803
supradaddy0803's Avatar
The engine harness is the harness that connects to the ECU under the dash. It runs up the firewall and through the passenger side of the firewall and goes into the dash where the Computer sits. This is the engine harness. You may have to use some of the harnesses and connectors from the rest of the body harnesses. Those I am not to sure of with what will work between the two different body styles.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
