Old 02-02-2010, 10:09 PM   #1
supradaddy0803
supradaddy0803's Avatar
How much work did you do to the mating surfaces before you put it back together? I would have measured for warpage on the head and the block with a gauge. Also if the head wasnt torqued properly in stages like it should be then there is another issue. Also did whoever did it use the old head bolts? You know those have to be replaced. If it were me (and with a 1JZ I dont run into the BHG problem like you do) I would take the whole engine out take it to a machine shop and have it tested for cracks first thing. Cre was trying to tell you what you already found. Have the surfaces checked for warps then if everything checks good install ARP studs and a new HG. From every 7M owner I know they Smack you if you didnt invest in them.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
