Thread: wiring harness
Old 02-02-2010, 09:56 PM   #1
supradaddy0803
supradaddy0803's Avatar
The wiring harness is going to be different. As for the transmission easiest way would be measure all of the relative parts like lengths and mounting positions and see if everything will fit. I know a 7MGE will fit I have seen MK2's with 1JZ's in them before and the 1JZ is a little longer due to the turbo manifold.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
