Old 01-30-2010, 06:40 PM   #11
The RTV does go on top of where the plate and block meet. Put down about a 1/4" bead.... I'm pretty sure mine leaked because I put it on way too thin.
Get new grommets from Toyota or another parts shop if they have them... definitely use them. I'm using hex bolts with a flange head along with rubber/copper grommets I found at a specialty hardware shop. If you really want to make sure they stay in place you may add a drop of temporary thread locker to each of the bolts.
Still no oil pressure readings?
