Old 01-29-2010, 02:21 PM   #11
bradenman1
bradenman1 is on a distinguished road
Ok here are the part numbers:
Turbo water pipe:
16027
Nuts for the water pipe:
90179-06013
The IC pipe I need is:
17886
I also need the studs that go into the turbo water line that bolt it up to the turbo. I'm not sure if there bolts or if there's 2 studs and 2 nuts that go on over it. Power fab took it off before they shipped in my turbo
I may end up getting a universal kit for the IC piping. I'm not to sure how to set it up properly or what size pipes to run. Did you use the stock metal elbows (the ones below the intake and what not) when you installed your IC piping?
bradenman1 is offline   Reply With Quote
