Originally Posted by darkstarcooley
Mine does the same on cold days. As for the leak, if its just around a fitting I would suggest using Lucas power steering stop leak. Its kinda expensive at $10 a bottle. Mine took 3 to solve my leak problem.
Um, the capacity of the power steering system is only 1000cc's (33oz) so at 12 ounces a bottle you've pretty much
replaced the power steering fluid with something which is not intended to serve as a hydraulic fluid.. VERY bad idea.
