Old 01-27-2010, 10:12 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Well, I don't know a lot about what all was changed from one revision to the next.... hopefully someone will chime in with more. Is the engine VVT-I equipped? Post the numbers you do have (engine, ECU part number...)
If it helps, VVTi was not introduced in the Mkiv Supra till '99 (Japanese-spec). I'd guess if the Aristo engine is VVTi, it's '98+...
Life begins at 30psi.
