Old 01-26-2010, 06:39 PM   #11
I was saying that's how you do it if the timing belt is still installed... pull the EFI fuse and then rotate the crank manually. It's cake... no reason not to do it.
ALWAYS pull the EFI fuse (if not the positive battery cable) when you work on the engine!
