Old 01-25-2010, 01:03 AM   #11
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Originally Posted by bradenman1 View Post
Are the head bolts the big 18mm hex bolts in the spark plug area??
No, they are 10 mm socket head "capscrews"--there are 14 of them. You can buy a 1/2" drive metric socket with a male 10mm section, or just buy a 1/2" 6 point metric socket in 10 mm and a 10 mm Allen wrench. Cut ~3/4"+ off the long end and use that piece.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
